2022-09-13 01:18 PM
I've been through several posts already regarding applying wall end tools for complex profiles. I still cannot find a solution to this issue.
I hoping there is a solution to this now with Archicad 25.
2022-09-13 04:17 PM
I don't think we will see a fix for this anytime soon, but you never know.
The way I deal with capping Complex Profiles beams is to create a new profile based on the outline of the beam with a single material. You should be able to do the same with walls.
2022-09-13 04:31 PM
Basic and composite walls have parallel sides and the same building materials in skins from the bottom to the top of the wall.
Complex profile walls do not have to have parallel sides and they can have any number of building materials along the height of the wall.
The wall ends are just objects an can not cope with the randomness of the complex profiles.
That is why they can not be used with complex profile walls.
2022-09-20 09:44 AM
Thank for this response but I'm afraid I'm gonna need further description on this process. If you could direct me to another topic discussion for me to follow, that would be great. Thank you!
2022-09-20 09:45 AM
Hi Barry,
Thanks for the response. What you said does makes sense.
I do hope in the future there would be way for Archicad to do this.
