Wall Intersecting Lines
jaydenprosser7
 See issue with wall ends.
I have tried the settings in the complex profiles and composite profiles to turn the end lines on. This odes not help. All my layer intersections are the same.
TDabney
I've had the same issue and solved it by playing around with the "Line Pen" settings in the composites dialogue box...
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
TDabney
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
Thanks exactly it, there is a line colour setting for the edges of the selected composit materials!
AC26 3001 INT FULL - Laptop Win10 x64 - Intel i7-7920 HQ CPU @ 3.10GHz - NVIDIA Quadro P3000
