Wall Label - Text Orientation
romanb
Hello everyone,
I am trying to manage wall labels in ArchiCAD 24 (US version, running on macOS Big Sur).
Please see the attached image:
- Label #1 - this is a "NCS Wall Label 24". It looks almost perfect, except that the square must be rotated 45 degrees.
- Label #2 - this is exactly the label I need. I made it from lines and numbers, so it's not parametric.
I tried all labels, and I didn't find any label that I can use for my drawings to mark up walls.
Some labels don't have needed frame option, some just not rotate text vertically etc.
Any suggestions?
Thank you.
Roman
Palawat
I have one that is "similar" to what you are after, but it doesn't draw that thick line across the wall.
https://www.indigofigs.com/symbol-label-suit/
Just a heads up though, it is currently free but I plan to sell it in the next release (whenever it might be).
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.facebook.com/indigofigs
You can do your own label.
1) Explode the label you shown which is the nearest you could find (EDIT→ Modify→ Explode in current view)
2) Modify the lines as you want and in this case turn the square of 45°
3) The text must be an "automatic text" referring to a wall parameter or general parameter in your case.
If you want to put a "custom text", you will have to create a property "Custom text" and make available for your walls, and then choose the Automatic text field "Custom text" from the properties.
4) Select the "modified label" and in File→Libraries and Objets, Save it as Label.
Then try to use it by selecting it as type of label.
romanb
Thank you everyone for your answers.
I have actually found a solution on another forum here:
https://gdl.graphisoft.com/forums/topic/graphical-editing-in-section-markers
Roman
