Wall Markers
Hi:
Is there any way to create wall markers such as those in windows and door so when I use my layout renovation filter I´m able to turn off all markers?
I mean beside manually drawing them
I´ve tried saving walls as doors and windows but when I place them no element appears ....
Thanks
Palawat
For AC20 (not sure which version you are using), you can use "Identification and Property Label 20" that allows you to select Frame Shape, disable Leader Line, etc. Being a label, it will show/hide with the wall associated.
Or, if you are one of the brave souls, I have a custom made label for you to try. It's still in beta though.
http://palawat.net/blog/palawat-symbol-label-suit-20/
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
Hi palawat
This brave soul will give your label a try and report any errors back. From a quick read it looks like it may work as a keynote object as well. Thank you for your generosity.
Thanks!
Going to give it a try.
Regards
