Document & Visualize forum
Wall Materials not joining/claning up
Is there is some simple setting i cant find so that the materials join without showing the gypsum running through the middle of the adjoining wall?
1 REPLY 1
Check that the wall reference lines are actually touching each other.
If they are then check the 'Legacy' settings in the Options menu.
If the Legacy is already off, then it is probably an issue with Building Material strengths or more likely the walls are in different layers and each layer has a different intersection priority number (or it is set to zero if they are in the same layer) - this will prevent them from trimming.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
