SOLVED!
Wall Tags
Why is it so difficult to place a Wall Tag/label  with this sort of readable orientation?
How are you doing it?  What Label are you using ?
1 ACCEPTED SOLUTION
Solution
David Maudlin
Steve:
This can work. Note the Label Orientation is set to Custom Angle, although the angle itself does not matter.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
3 REPLIES 3
what I've learned is that AC walls like to be drawn in a clockwise orientation. when I'm tagging walls I turn the wall reference vectors on and use the "Invert Wall Direction" and or "Modify Wall Reference Line" to mirror in place. I do this instead of trying to make the labels do too many gymnastics. The only downside to this is to try and do this before you have too many dimensions set. They'll require attention as well.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Solution
David Maudlin
Steve:
David
Thanks.  That works easy enough. I was having a difficult time getting that specific orientation with the other Labels I was using.  Composite Profile Name 25 and Property Label 25.  Not sure why I was not using the NCS Wall Label.  I usually do.
Learn and get certified!
