This is what we've done too: just add some fields for walls, roofs, floors, sub-floors etc to the template so the copy paste works a bit better.
You can export your entire project info to xml and import it. So with some clever editing you can quickly swap between files too.
Another tip: you can divide up the description in to a few autotext fields and combine them as needed. For some more complex projects this might make changes quicker.
www.leloup.nlArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
