Document & Visualize forum
Wall component schedule not matching wall composite profile
Johann_P
I have found that the Wall component schedule does not matching Wall composite profile.
This is rather worrying....
I seem to have 2 additional layers in the wall schedule that does not exist in the composite profile.
Am I doing something wrong?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
10 REPLIES 10
Vinicius Guedes
Graphisoft Alumni
Graphisoft Alumni
Hi, @Johann_P
One thing I noticed in your criteria is that it's not organized with "()", as suggested in my image.
It can cause some issues in scheduling components.
You can try sorting criteria types with "()", and send more detailed images or the .pla file in a WeTransfer link for a deeper evaluation.
Johann_P
Thanks  Vinicius,
I have added the brackets as shown in you reply, but no change.
Here are some more detailed images.
I hope they are sufficiently legible.
Windows 10 Pro
bouhmidage
Add some extra parameters in the field area, renovation statue, composite name, story level, to check from where they come
Archicad 23
Windows 10 professional
They seem to remain and seem to be identical to the duplicated layer.
Windows 10 Pro
So I solved it by doing the following:
I had 2 instances  "Wood - Siding" in the schedule.
One layer had a "Custom Text" description which was the only difference between the 2 .
When I deleted the "Custom Text" the 2 instances merged.
When I renamed the "Custom Text" to what I had, the 2 instances remained merged, thus solving the problem.
This duplication happened as I was making changes to the Wall's composite profile.
Still, Surely the Wall Component Schedule should match the actual wall, shouldn't it? And not have random elements listed that could cause mayor confusion if the drawings are issued with such errors?
Windows 10 Pro
Johann_P
I had the exact same problem with Wall 2
But this time deleting the "Custom Text" didn't solve it.
I had to remove the "Custom Text" field entirely from the schedule and re-add it.
Windows 10 Pro
Johann, just one question to clarify:
You are talking about Wall Complex Profile, but your screenshots show the Composite Dialog.
You are using Composites, right? You are not using Complex Profiles, right?
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Thanks Laszlo,
Indeed, it should be "composite".
I have edited the topic and my references to be "composite" and not "complex"
Windows 10 Pro
Johann,
I have a curious idea:
In your screenshot, I can see that you have 5 skins that have the "Finish" skin type.
Could you modify 3 of them to "Other" so only the 2 outer skins ("Wood - Siding" and "Masonry - Finish") have the "Finish" skin type.
Then check if that makes any difference.
Johann_P
Back to this issue....
I still cant solve the additional items in my schedule.
I've scheduled "Custom text" because I need it, but this causes Archicad to duplicate the skin in the schedule.
The 2 skins circled in yellow does not exist in the wall type.
But when I delete the custom text underlined in green, the schedule is correct.
But I need the custom text.
Is there a different way I can add text in the schedule for additional descriptions?
Windows 10 Pro
Labels
