Document & Visualize forum
What does "(!)" in a tab mean?
LeeJaeYoung
"(!)" What does the table mean?
other
AC25 5010 / AC26 4019 on window 11
4 REPLIES 4
It means that the view settings (layer combination/scale/etc.) of the view as currently shown in the tabbed window are not the same as the settings that are saved for the view.
Thank you so much
I found misssing in view setting
When you open a view from the view map, it will open with the settings as saved in that view and the tab should not have an (!).
If you now manually change any of those settings (layer, scale, graphic override, etc), then the tab name will now have a (!) to indicate that something is not the same as the original view settings.
Double clicking the tab name will reset the default settings for that view.
Versions 6.5 to 25
Yeah! thank you.
This time it seems to have changed the name of the GOC, but Missing appears as if I deleted it. So I solved it by creating a new one. ^^
