Lockers wrote:
Hi guys,
What am i missing here!! I've attached a screen shot of my model in Artlantis, how do i: A) add lights in Artlantis and B) how do i control the ones I've exported from ArchiCAD?????
Thanks
Have you worked through the (albeit limited) user manual / help file? There are zillions of settings in Artlantis that you will not discover without readying about them.
You have to understand that Artlantis has views, somewhat like ArchiCAD. So, in the Perspective Inspector (shown below), you can choose which of several heliodons (suns) to use and you can enable as many (or none) light 'groups' as you want, as well as control layer visibility. All of this is saved with a view. There are perspective, axo and many other views.
So, if you do not have a heliodon selected and your light groups checked, it does not matter if the lights are on in the light groups, or that the sun is bright - nothing will be lit.
One of the forum moderators • AC 26 USA and earlier • macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
