2016-01-21 12:26 AM - last edited on 2023-05-17 03:49 PM by Gordana Radonic
2016-01-21 01:21 AM
2016-01-21 01:55 AM
2016-01-21 01:59 AM
s2art wrote:Unless you tell Archicad to ignore the ID by ticking the ID box for windows/doors then you will get a new ID each time you place a window.
If you keep selecting from the list of favourites they will have the same ID as all settings are kept.
2016-01-21 02:10 AM
Barry wrote:s2art wrote:Unless you tell Archicad to ignore the ID by ticking the ID box for windows/doors then you will get a new ID each time you place a window.
It probably still won't be what you want so either manually change it or use the ID manager as Stuart suggested.
The attached image is for something similar but you need to go into the windows/doors section and tick the ID box.
2016-01-21 02:46 PM
2020-04-02 04:34 AM
