Window Legend - Remarks
I deleted the "Remarks" from the Window Legend, but now I want to add it, but I cannot find it anywhere in the Field pull down panel. Where can I find it?
Hopefully I will be notified when a reply is posted because I checked that on, but I was not being notified when a reply was posted.
Stress Co_
Are you clicking "Add Fields" or clicking the pull down arrow and then selecting "Library Part Parameters"?
See Barry's post here:
https://archicad-talk.graphisoft.com/viewtopic.php?f=34&t=69375&p=308612#p308612
You can then search for the parameter.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
4 REPLIES 4
Click the little arrow next to 'Add Fields' and choose 'Library Part Parameters.
I am assuming it is a library part parameter of your door/window object.
I have done that and used the search criteria, but I cannot find the "Remarks." Can you give it a try and see if you can find it. Thank you.
Stress Co_
Marc, thanks.
