Select the Drawing on the Layout and use the Open Source View command of the context menu (right-click to access it).
You can then right-click the Tab of the Elevation and select View Settings, then check which Model View Options combination is used.
Then go to the Model View Options Dialog and check the settings for Doors and Windows in the "Construction Element Options" panel. Maybe they were set to the "Show Opening Only" option somehow. If so, modify the Model View Options settings, then update the Drawing on the Layout, which should now display Doors and Windows.
