Wishlist | Mesh to be able to show Major and Minor Contours automatically
Josh Verran
It would be great if there was a way that the Mesh tool could incorporate some function that would enable a user to show Major and Minor contours.
Also to on the fly change what the definition for Minor and Major.
For example Minors at 100mm increments, Majors every 10x (1.0m), or Minors every 250mm, Majors every 4x.
The below example is from Vectorworks.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
LinkedIn | www.creativespace.co.nz | Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
5 REPLIES 5
Emil Meijer
Graphisoft Alumni
Graphisoft Alumni
Agreed, this would be a really nice feature to have embedded in Archicad.
As far as I know, this is possible with the LAND4 Add-on tool developed by LAND SOFTWARE A/S (they have a 30 day Free Trial version that you can try out!)
furtonb
57 EUR a month seems a bit steep to have this functionality.
+1 to have this as a native feature.
a workaround could be to use morphs as cutting planes at the desired elevation and use SEOs to extract the contours. alternatively you can also use the AC-GH connection to produce the elevation lines.
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
Josh Verran
I think one of the key features, if it was to be developed, is that it should still use the native mesh tool, rather than an object or plug-in. This would assist with consistency and coordination.
Nader Belal
Mentor
@Josh Verran
If you would like another way to achieve what you want and make personal customization, I can other another method on which you can build what you need. Click download on the pic.
Create Topographic Contours In Archicad Using Rhino+GH 1/2
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
