2015-10-11 11:47 PM - last edited on 2023-05-30 10:02 AM by Rubia Torres
2016-08-04 08:49 PM
Tincan561 wrote:
I have a wrapped wall end, which works fine in plan.
How do I turn off the visibility of the wrapped end line meeting the wallboard in S/E views?
2016-08-05 07:56 AM
2016-08-05 07:43 PM
Chris wrote:Well, there is no solution. There is an error in GDL code of this object that prevents it from working right. PM me if you need this object fixed.
Did you ever find a solution?
alemanda wrote:I think the best workaround (as with any object in the default library) is to spend a few minutes finding and correcting errors made by original programmers and get any object working right.
One of the best, probably the best workaround is to model it with a custom profile column (made with complex profile).
I've learnt here in the forum and it works.
2016-08-05 07:56 PM
