Wrapping textures around a corner
Glenn Willey
Hi Community,
I working on a project where I have a repetitive wallpaper that needs to wrap around an internal corner. The wallpaper is made up of large scale photographs and falls across the corner half way through a photo. I would like this to wrap. Haven't been able to figure this one out. Any ideas?
2 ACCEPTED SOLUTIONS
as the corner will be made from 2 independent walls, you will need to align the texture in 3D on either or both walls.
DGSketcher
Legend
As Barry said. Here's a link to Align 3D Texture in help
4 REPLIES 4
DGSketcher
Legend
Thanks Barry.
Thanks for the link @DGSketcher
