ZONE Fill Colour does not show in Master file
I have an apartment with Zone coloured (yellow) as picture attached. When I saved as a MOD and brought into a master file, the Yellow colour of the Zone does not show anymore although the Zone is fine. I checked the Vectorial Hatching. Other Fills are still fine.
Does any body know what's missing?
Thank you
4 REPLIES 4
The Graphic Overrides control whether the zones fills are solid or transparent.
You are probably using a different GO in the master file or the rules are not set up the same.
runxel
Legend
Which would mean his signature is outdated (AC18/19)
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Another reason could be: Different attributes with same index number in each file.
Hotlinked modules can become a nightmare if you don't regularly check attributes.
Hope that helps.
Thanks for all your replies.
I worked it out. There are a floor slab and another overall zone sit on top of it. I shuffled the order and it worked.
Thanks again
