2020-12-0812:00 PM - last edited on 2023-05-1911:56 PM by Gordana Radonic
Simple and hope very simple answer as to why my control of zones is not working ?
see screenshots.
the correct classification is used : see the GRAPHIC OVERIDE SETTINGS - both the overide settings and the respective settings for the classification - zone. Also atatched.
No idea why the zones are not appearing in 3D as volumes in blue as they should be.
Download the attached zip (it has 1 .xml file in it) and import it to your Graphic overrides.
Change the rule setup: home stories, surfaces, element type, and delete the unnecessary rules if you want.
