Zone Stamp = always centered on zone?
joimagg
Is it possible to have a zone stamp always centered vertically and horizontally inside the zone?
This is possible with the "Area Text" in Fill...and its such a nice feature when doing quick zone sketches.
Kind Regards
1 REPLY 1
Marc H
I'm not aware of an auto setting, but it will place the stamp where you confirm (hammer) the room. Typically, I pick the center of the geometry or, if equipment, casework, and/or furniture is visible, in a clear area of the floor.
If I have a line of spaces and want the stamps to line up, I will either set a guideline before or after the first placed stamp, or I will drag copies and then go back and edit the zone id.
Hope this helps.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
