2019-02-22 07:50 AM - last edited on 2023-05-19 03:48 PM by Gordana Radonic
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2019-02-25 03:26 AM
2019-02-25 04:58 AM
2019-02-26 12:01 AM
2019-02-26 02:36 AM
2019-02-26 03:16 PM
2019-02-26 08:19 PM
Lingwisyer wrote:
I get a syntax error if I try to add the plain text after the calculation...
Can you get it to convert to meters when the length settings are set to millimetres?
Ling.
2019-03-15 09:24 AM
2019-03-16 08:01 PM
2020-06-16 10:33 PM
Ling.
Here is a modified version of the Expression.
In the Dimension Units Dialog, Length Units have "Meters" set with 2 decimals.
So the Property would be: "6,00 m"
So I multiplied the "meter" value to get millimeters, then used the SPLIT function to cut the decimal separator and the 2 decimal places on its right side.
Converting from millimeter to meter can work similarly.
See the attached image for the Expression.
