angled dimensions AC21
Hi guys, i can't remember how to convert back to being able to dimension on an angle, I've looked on google, but still stuck.
ant ideas?
stuck with this
https://imgur.com/v9HPc8q
need this please
https://imgur.com/uUiANYC
thx
9 REPLIES 9
You had to choose this option :
And just before the validation you can click on a line, a wall or even a guide line that has the same angle
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Post moved.
Please don't just post everything in "Archicad+" section.
Barry wrote:
Post moved.
ok thanks barry
Thanks Christophe, i tried this except it does not work, has it something to do with it being an imported file from someone else template set up?
Thanks
You need to set the angled geometry method.
Thanks Barry, when i click on the geometry method, nothing happens, no options?
https://imgur.com/apIJk1I
You need to hold the mouse button for just a fraction of a second longer to get the pop-out.
Please give us a screen capture to understood your setup
One of your parameter is wrong
It might be better and faster if you tell us All your parameter by a or some screen capture
You had to begin with my first advice
Christophe - FRANCE
Thank you guys, Barry when I hold the geometry method like you said it gave me the extra option.
Thanks so much you guys for the help you give
