Document & Visualize forum
archiBam 3D trees from the garden works library: unlocked!
SenecaDesignLLC
Hello everyone,
I have been on a search for sometime now to find out who created these trees, and up until now I have had not luck. Aaron Bourgoin contacted me about one of my objects recently and while we were talking we got on the subject of the trees and he got me in contact with the right people. I have been given the unlocked trees to modify and share! I can give them to anyone who would also like to see them. they are currently in german. in order for me to share them i have been asked to collect names and emails of the people i share them with. These trees have great potential but need to have some updates and options added. Pm me if you are interested. lets all start pitching in and making archicad even better!!
FREE wall Accessory framing and coverings
bit.ly/BIMRithmWallAccessories
FREE Truss object.
https://bit.ly/BIMRithmTrussV1
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
19 REPLIES 19
Those would be the trees that are a bit more crude version of the stuff VB Visual makes? I recall there being a german only library of slightly nicer trees too.
I've recently started using ye olde garden works trees, as our VB Visual library is for Artlantis. They work in ArchiCAD 18 just fine (and render fine too). They're not as smooth as the VB Visual ones though.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
SenecaDesignLLC
they are similar to the vb visual. i recently purchased their library and it is awesome. however these trees are neat in the fact that they randomly generate different branches and trunks. at least that what it seems to be doing. the vb visual trees also do not have any conifers. and almost all of the branches on those are images. the Archibam trees have some 3d branches and then leaves with smaller branch images.
Im currently working on editing the pine trees to be higher detail imagery and going to make a version with cutout images to look better in bimx.
FREE Truss object.
The artlantis trees from VB visual are RNG too, I would've assumed the ArchiCAD version worked the same. Are they the same whenever you copy them, place them new, etc?
I tried the ArchiBAM ones in a fairly large shopping mall / leisure project mock up for BIMx to be shown on an iPad, I could not get away with the polycount they generate, even at low detail-ish poly settings, once you start placing a large number of them.
www.leloup.nl
Windows 10 Pro
SenecaDesignLLC
Yup, no random in archicad. The archibam trees are very old from my understanding, But the code they hold offers many possibilities, such as creating random plants similar to the vb visual trees, plus it has pine trees. Ive been messing with the code a little with the small amount of spare time i can accumulate. I Bet with some updating they might not be so high in poly count. There are a couple of the trees that will freeze in 3d sometimes, im guessing something with the random. They work great for smaller residential products. I have managed to make them look decent for renderings as well. i am currently updating the images for the pine trees. but im doing them as cut outs to help with the transparency issues that arise in bimx. For being free they are pretty cool. and now with access to edit the code they will just get better. and always be free.
What kind of pc do you have components wise?
FREE Truss object.
Oh the PC is fine (HP workstation), this was just a case of needing a BIMx to run on iPad for a client and it being a large project (big mall, leisure, indoor sports project) and there being a lot of the trees. I used them for indoor plants.
www.leloup.nl
Windows 10 Pro
Craig Bagley
Have you got Bush3_GWL? Tried to open it for some minor editing, and could not (password protected). I'm using it in a simple OpenGL render, but I can't access the image used to try and darken it.
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
We are using the massivator library found here: https://youtu.be/b5_QGzv6RHQ
It gives pretty good results in both cinerender and OpenGL if you hide the contours.
www.leloup.nl
Windows 10 Pro
Thank you, Erwin. I found a substitute plant in the massivator library that works for me. Incredible library . . . . is there an English translation of the YouTube video? or is there something in the video settings to be able to translate?
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
As it is a YouTube video, go into the settings and turn on captions.
To begin with you may only have an option for Russian (auto generated).
But try again and you should see an option to auto translate to your choice of language.
Versions 6.5 to 25
Found it . . . thanks, Barry
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
Thanks again, Erwin.
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
Barry beat me to it.
Also the preset are just a starting point. The library comes with a lot of surfaces for bark, leaves, flowers etc and the object itself is a clever array tool that scatters and scales simple shapes that you can apply clever surfaces to.
With contours on, it looks a bit messy, but the renders are reasonably quick and with contours off they look fine too.
The trunks are a bit narrow and seem to spew out errors on some Archicad versions (I think 21 and 22, not sure now, I don't get them on 23).
www.leloup.nl
Windows 10 Pro
Thanks again, Erwin
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
Thanks for sharing this link to the free Massivator library, @Erwin Edel !
This is remarkably clever with good results also for BIMx.  Graphisoft should hire this woman!
Note to others in case this info helps … the text description of the library with the download link does not appear for me on my mobile device’s YouTube app… but does show up in my desktop browser from the link that Erwin posted,   Also,  my desktop browser offers an English translation of the Russian audio via captions as described by Barry and Erwin in this thread.  But, the YouTube app on my iPad only offers the Russian captions.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6.2, iMac Pro
Karl: You wrote ". . . the text description of the library with the download link . . . . does show up in my desktop browser . . . "
I'm not totally clear what the text description is, and where it's found (or if it's even useful). My browser is Safari, and I'm using MacOS 10.13.6. All I can find is what Google Drive shows in the screenshot below.
Normally wouldn't be bothered with such trivia, but this library is pretty cool. I did find the English translation of the Russian audio captions.
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
I meant the text description of the video... which included the link to the Google drive download... does show up on my desktop browser... so I could get to the download page that you show from there.  From my iPad/Safari, that description and the link did not show... only user comments.  Weird.  Sorry for the confusion.
Thank you, Karl . . . . then I'm not missing anything.
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
There should be small V-shaped arrow at the bottom right below the video that unfolds as the description on mobile devices, I think.
Not entirely related, but I only discovered this excellent youtube channel through an article on the Graphisoft website: https://graphisoft.com/case-studies/Archicad-revisiting
www.leloup.nl
Windows 10 Pro
@Erwin Edel That is a fantastic article!  It is perhaps the best overview of the power of CineRender/Cineware that I have seen... and yet somehow I'd never seen it, or most of the other case studies in that part of the Graphisoft web site! 🤔 Strange that there are no dates (that I can see) on any of the articles either...
Svetlana Kravchenko is a rock star.  Thanks for pointing all of us to this and her videos. 🙂
Labels
