Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
Interior elevation <Orientation> autotext
Is there a way to limit the and autotext for interior elevations to just the cardinal directions (N, S, E, W)? Due to energy code requirements, we cannot use ordinal directions (NE, SW, etc.) Our building is oriented just north of NE, but for energ...
Anonymous by Not applicable
  • 233 Views
  • 0 replies
  • 0 likes
Hiding Door Tags in Specific Views
Hello, is it possible to hide door tags in specific floor plan views? For example, I have a main first floor plan view where I want door tags to be visible, and I have different first floor plan view with different information where I want the door t...
  • 201 Views
  • 1 replies
  • 0 likes
Wall Dimensioning
When I dimension the length and width of a room, ArchiCAD automatically dimensions the wall thickness as well in addition to its length or width.... I am constantly selecting the wall thickness and deleting it--- how do I turn off this feature?
dhnguyen by Participant
  • 234 Views
  • 2 replies
  • 0 likes
Schedule: Some object don't show 3d view
My bath accessories schedule shows the 3d view of the robe hook in only in some instances. Why? Same library part. Object exists in office library on server. Or in office library on Dropbox. Modules read the same library as the host file. Multiple mo...
  • 669 Views
  • 1 replies
  • 0 likes
Drawing Titles in AC 22 USA have changed.
Drawing titles in AC 22 have changed a bit and not sure how it is currently working. Standard Drawing Titles in AC 22 are: Built in Drawing Title NCS Drawing Title 2 22 NCS Drawing Title 22 Simple Drawing Title and Load Other Drawing Title. If you ch...
  • 248 Views
  • 0 replies
  • 0 likes
Continuous wall with varying thicknesses
How do I create one continuous wall where the wall thickness varies as in the attached screenshot? I've managed something using the trapezoid or polygon option to create separate sections, but I can't then get them to join properly. If I try to join ...
  • 501 Views
  • 4 replies
  • 0 likes
Add shader to layer at top of stack?
Hi, I use the Layer system in CineRender's surfaces quite a lot, as we can build up quite complex maps that way. One really annoying thing is whenever you add a new shader, it adds it beneath the current top shader, rather than at the top of the stac...
Leaf Thickness in Door Schedule
Hello, I am currently working on a door schedule. I want a field which displays a doors width, height, and thickness. I decided to go with the Nominal W x H x T field. This field does accurately show my doors width and height, but it shows the wall t...
  • 488 Views
  • 1 replies
  • 0 likes
Labels
