Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
Send Teamwork message to self
Hi It used to be possible to send messages to yourself from the app to ARCHICAD Now I only see the option to do this from ARCHICAD to the app This is devastating to any workflow where you need to communicate changes to not just the team but yourself....
Anonymous by Not applicable
  • 705 Views
  • 0 replies
  • 0 likes
Invisible walls in layout (AC22)
Hi! I can't see walls in a layout view. I pin the drawing of a plan to my layout and there are no visible walls. I think I have tried everything (which obviously is not true ) and found no solution. Any help? Piotr T
  • 620 Views
  • 4 replies
  • 0 likes
Resolved! 360 Views on Webpage
I'd like to have something like this: https://www.roomsketcher.com/features/360-view/ I want 360 views on my webpage of my model. Best would be a dynamic model viewer that was connected directly to the BIM Server, but I guess that's out of the questi...
  • 1005 Views
  • 8 replies
  • 0 likes
Invisible Link in published PDF
Hi all, For some reason my published pdf creates an invisible link on the floor plan page that has a rule to go to the elevation page and zoom to fit. I've looked everywhere, checked the markets and layout drawings for any backreferences but can't se...
  • 179 Views
  • 0 replies
  • 0 likes
Door Marker not Showing
The marker on two doors are displayed, but the marker of the third door is not displayed, and all three doors have the same marker settings. Can someone figure that out? Thanks.
  • 569 Views
  • 2 replies
  • 0 likes
Multiple Transparency, False Light
Hi all, I appear to be getting false illumination when rendering through multiple panes of glass into a shaded space... Render settings are the default Outdoor Daylight Fast settings with the Ray Threshold increased to 10. Ling.
Labels
