Document & Visualize forum
Forum Posts
AC21 Label / annotation object?
Hi! I haven't run AC20 because our old template was huge to change. But now we finally building a AC21 template. There isn't any way to label objects automatically like we could in older ArchiCad versions with the little checkbox? I've tried to use d...
Anonymous by Not applicable
  • 572 Views
  • 1 replies
  • 0 likes
Sheet Number Reference with Autotext
In construction documents we often say, for example: "See Sheet A-601 for detail." Is it possible to use autotext to select the sheet number the detail is on or the detail itself so if the sheet sequence changes or the detail moves elsewhere, the aut...
  • 582 Views
  • 2 replies
  • 0 likes
Cloud Rendering
I've search and asked before and there doesn't seem to be any cloud rendering infrastructure which can be incorporated into ArchiCAD, like Revit does. Revit has a button that sends off the scene to a cloud render farm. Anyways, is there some other wa...
  • 1934 Views
  • 0 replies
  • 0 likes
Continuos elevations
I have a box enclosing an stair case, not all the angles of the box are 90 degrees, some are some not. I want to create a continuous elevation of all the sides of the box. Is that possible? Another question that arose me when I was an Autocad user it...
  • 1486 Views
  • 6 replies
  • 0 likes
ROOM FINISH SCHEDULE
I cannot seem to get my room finish schedule to populate with information input into each zone. I am using Zone Stamp 02 21, and where in the stamp do I put information for it to show in the schedule. The finishes are not coming from the model, just ...
  • 1309 Views
  • 2 replies
  • 0 likes
Window and door ID in dimension
Is it possible to show the ID of a door/window in the dimension? It is possible to show the height of the door/window, therefore the dimension knows which door/window you're dimensioning, so it should also know the ID of the door/window
  • 533 Views
  • 0 replies
  • 0 likes
