Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
How to remove the underline on elevations ?
Hi, I'm looking at the drawing selection settings on layout to remove the underline underneath the elevation name. The only place that I can see if the title line option, which allows you to change colour and line type. I've tried setting the line to...
Anonymous by Not applicable
  • 4126 Views
  • 3 replies
  • 0 likes
painting queries
I Have a few queries regarding painting. 1)How to paint a wall with 2 or more colours? 2)How to replace a whole painted structure with another paint? 3)Is it possible to use paint shades from jpeg image file or shade cards from paint manufacturers we...
  • 5787 Views
  • 8 replies
  • 0 likes
How to use 3D view properties in 3D document ?
Hello, So I've created a 3D section through a model I've made ( It's a tent type shelter inserted into a bag ) The 3D view is ok ( any tips of how I can separate the tent and bag, colour wise ? ) but as soon as I put it into a 3D document, there are ...
  • 2862 Views
  • 3 replies
  • 0 likes
Automatic Interior Dimensioning
I have a fairly small problem that is driving me crazy. I have no problem with using automatic exterior dimensioning, but when I try to do an automatic interior dimension, I get the following warning: Cannot draw dimension: zero or one perpendicular ...
  • 4109 Views
  • 2 replies
  • 0 likes
Losing a drawing in a "viewport"
You'll have to excuse me but I'm coming from an AutoCAD background. My problem is this, I make a window on a sheet for elevations in the layout book and the next time I go back to it the drawing has shifted from the view. The only way I have found to...
  • 2564 Views
  • 1 replies
  • 0 likes
make my elevations sing !!!!!!!
We have the elevations on, checked the cut line - we have the sun & shadow as in 3d window, vectorial sun shadow ticked, and they still look flat and not bright enough even though we have the sun straight at it ? ? ?? Any thoughts would be a help Mer...
  • 6182 Views
  • 3 replies
  • 0 likes
Trace reference bogging down
Usually the switching on of a trace reference or changing references is almost instant. But once in a while something happens to make the turning on or changing of the trace reference take about 30 seconds. And once it's on, zooming or panning also t...
problem with transparent background
Hello, I have the following problem. In used a JPG with transparency (the topographic plan which should be visible on the final presentation) but it won't be exported in the PDF . If it is exported, it is opaque, without transparency thus covering th...
  • 3355 Views
  • 1 replies
  • 0 likes
saving an image from the VBE
Hi Xmas cad users We have just started to use Archicad 13 VBE. Is is possible to save a screen shot or image from the VBE so it can be used as s Jpeg or PDf ???? Thanks all and HO HO Merry xmas
  • 2655 Views
  • 1 replies
  • 0 likes
Labels
