Document & Visualize forum
Forum Posts
Dimensions superscript
Just upgraded to AC14 and I see that the dimensions input method has changed. Before it was possible to add a "m" super script in the custom dimensions dialoge box, now I dont see a way to do it. Is it still possible? Is there way to add the "m" supe...
Anonymous by Not applicable
  • 2532 Views
  • 3 replies
  • 0 likes
Borderline in Masterlayout
I made my first master layout, with border wich I want in 0,8mm thickness, but I cant find were can I change it. So right now my borders are in 0,13 mm... I know about this colours palate in line settings, but I don't want any colour, i want my perso...
  • 2443 Views
  • 4 replies
  • 0 likes
Light box
How can I make an image look as though it is back lit with lightworks. I create a material using a jpg as texture and apply it to e.g. a wall. I've tried no end of messing with the reflectance and transparency, but can't get it to look right. Any ide...
  • 1865 Views
  • 2 replies
  • 0 likes
Plotmaker - Lest We Forget
For those of you who miss Plotmaker as much as I do, a desktop wallpaper in her memory: http://blog.cadimageworld.com/2010/08/plotmaker-lest-we-forget/ Direct Links: 1920x1200 1680x1050 1280x1024 If anyone can give me more accurate dates 'twould be m...
Auto-text in labels?
Hi everyone, I'm working in construction documentation of a project. To be precise, I'm taking care of the construction details. We customized all fills to match the products used (rock wool insulation, waterproof bitumen membrane and so on). Now, it...
  • 3265 Views
  • 2 replies
  • 0 likes
Interactive schedules and sections/elevations
Hi everyone, I'm trying to decide whether to use interactive schedules (easier to use) or lists (anal, if you ask me) to generate automatic quantity take offs. For some elements (e.g. metal sheeting) I'm using a dedicated line type (say "copper rain ...
  • 1340 Views
  • 1 replies
  • 0 likes
Master Layout Costum Size
Is there a minimum to the custom size of the Master Layout in AC 13/14? I am trying to set up a business card layout 85x54 mm. I can not get it smaller than 85x80 mm. Is it not possible or what do I do wrong?
  • 3206 Views
  • 6 replies
  • 0 likes
colored floor plan
How to generate\create colored floor plan for presentation from normal archicad plans? I have attached a sample image of my requirement.
  • 23680 Views
  • 10 replies
  • 0 likes
