Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
Text Sizing
Is the text pt size used in Archicad 10 the same as in a ms word document file? I find that in order to emulate the real print size of 55 pt font in a word document that I have to use a 30 pt font in archicad. I checked the scale it's at 100% I know ...
Anonymous by Not applicable
  • 2954 Views
  • 3 replies
  • 0 likes
Builder Dimension 10?
Anyone out there using the "builder dimension 10" as the marker for their doors and windows. I don't really care for the current marker style options and the lack of a moveable hotspot so I'm scripting my own. All of my work is in imperial units but ...
  • 7388 Views
  • 9 replies
  • 0 likes
shadow catcher
isn't the shadow catcher material supposed to just receive shadows but not cast shadows? when I set it it both receives and casts shadows! I'm trying to do a shadow study where I can see the shadows of my building but not the other shadows, then I mu...
  • 8365 Views
  • 8 replies
  • 0 likes
problem with alpha channel, need help?
I'm very new to ArchiCAD...I created an alpha channel texture in order to get joints on a wood floor, but when I rendered it (lightworks) w/ the bump map selected, there is a strange texture that shows up in what looks like a tile pattern (there are ...
  • 3956 Views
  • 7 replies
  • 0 likes
Cut plane problem
Maybe someone has solved this one: I have a plan with a short wall (4'-8"h) beside taller wall. The tall wall has a window with a sill height of 4'-9". I want both walls to appear "cut" and the window to appear in plan. If the cut plane is set to cut...
  • 11455 Views
  • 20 replies
  • 0 likes
perspective rendering in hiddenline
I am trying to get a perspective view in hiddenline format, this will be in all in black and white and I want straight lines, I can use plotmaker to do that import the 3d generated view and it will be fine, but I want to correct some of the lines bef...
  • 2572 Views
  • 4 replies
  • 0 likes
Labels
