Document & Visualize forum
Forum Posts
General light settings before rendering?
Hello. I have used ArchiCAD 10 for about 6 months, and as I get better at it, I have higher expectations to my renderings. Is there any general light settings you should have before rendering? Now I haven't changed anything with regards to ambient, c...
Anonymous by Not applicable
  • 14072 Views
  • 21 replies
  • 0 likes
PDF's missing in publisher setting for V10
Hi all, We using V10 for some of the project here, we also have v11 installed to our computers, but, I have no idea why "pdf formate is missing in publisher setting for v10", v11 is working all right, just funny going on with v10. please find attache...
  • 1477 Views
  • 1 replies
  • 0 likes
critics, LW AC 9....
I rendered this using lightworks about 6 months ago... and I can truly see alot of things that I could improve on when I look back at it. Background, roughness on certain materials, glass, lighting. I for one, wish I could've done different on the fl...
  • 1986 Views
  • 2 replies
  • 0 likes
Rendering Cutoff
I'm experiencing something in Archicad 11 that has not happened in 8 or 9. My sketch rendering is being cut off. I've had this happen on several houses now. The attached photos will show 1.) The camera view before rendering and 2.) the final sketch r...
  • 2302 Views
  • 4 replies
  • 0 likes
Project Template in AC11
I had previously created my project template in V10, should I open and save it in V11 or recreate it in V11. The reason I ask is that I have read that some people are having problems working on files in V11 that were started in V10. Thanks, Jim
  • 2184 Views
  • 5 replies
  • 0 likes
Plotting Aerial photo
Hi all, I have some problem plotting Aerial Photo from Layout book, the problem is that the Aerial photo doesn't seem to be appeared on the layout book, it's just ""blank""~!! I have no idea what caused it. may be it is because the file of Aerial pho...
  • 1270 Views
  • 1 replies
  • 0 likes
Title Types resetting them selves
We're having a problem at the moment where we insert a custom title type on our drawings, and then the next time we open the file the title type has changed back to the default 'Built In' drawing title. Our custom titles are still loaded and availabl...
  • 4638 Views
  • 9 replies
  • 0 likes
plotting fills
In AC10 I would have solid fills with color set to grey and they would print or plot grey, and thats setting the print or plot settings "black and white (not grey scale). Now in AC11 those same settings print or plot solid black. I have wall fills se...
  • 1295 Views
  • 1 replies
  • 0 likes
Pretty, coloured floor plans
How do I set the floor plans and elevs to show each material's colour for printing/presentation? Is there a way to render true floor plans and elevs other than by rendering similar model views? Many thanks.
  • 4698 Views
  • 6 replies
  • 0 likes
