Document & Visualize forum
Forum Posts
Pretty, coloured floor plans
How do I set the floor plans and elevs to show each material's colour for printing/presentation? Is there a way to render true floor plans and elevs other than by rendering similar model views? Many thanks.
Anonymous by Not applicable
  • 4701 Views
  • 6 replies
  • 0 likes
Panorama reversed when mapped to wall
I'm working in AC9, and trying to create a proper window view. When I map a panorama as a texture to a circular wall, it's reversed. On a straight wall, I seem to be able to control it by drawing the wall right to left instead of left to right. That ...
pdf creation problem
Hi We just upgraded from ArchiCAD 10 to 11 and are beginning to use it. When creating plots or pdfs directly from Layout Views everything plots fine but when using the Organizer-Publisher, all the text and dimension text disappear from the final pdf....
  • 1014 Views
  • 0 replies
  • 0 likes
Lightworks Phantom Light Source
I am experimenting with various lightworks lighting options. To start off with (ie. baseline) I want to turn off all lights period to have a black render, then I will be adding various light sources in individually to see how they look. So to start I...
  • 5492 Views
  • 10 replies
  • 0 likes
Select one and all are selected
Problem I have is when I change the material selection on a column that I have put in front of a house, all the wall materials are changed as well even though they were not selected. I can change the colour but not the materials.
  • 2592 Views
  • 7 replies
  • 0 likes
archicad - 3d viz
hello, I was transferring a 3d file done in archicad and rendering it in 3d viz. However, whenever I try to nput any material it doesnt appear and whenever i render it just turns all grey. May I know how to rescue the problem? I am already in the mid...
  • 1424 Views
  • 1 replies
  • 0 likes
General Glow?
Another question... Anyone got any idea how to get this sort of affect happening shown in the picture below. Tilted spotlights,100000000 uplights? I'm trying various methods at home with some results....
  • 3805 Views
  • 6 replies
  • 0 likes
Detail Marker Link
I now use AC11 for Mac. Is there a way to link the Detail Marker to a standard office detail OUTSIDE (w/o having to import first into the Detail folder of the Project Map first) of the project file. I was hoping AC11 would have made this feature avai...
  • 2542 Views
  • 5 replies
  • 0 likes
