Document & Visualize forum
Forum Posts
PLT file displays as hairlines
I have created a PLT file from an AC10 layout using settings that (apparently) worked for PM9. I have the "Hairlines" checkbox UNchecked, and yet when I import the PLT file into an empty layout to check it the lines are all hairline. Does anybody hav...
Anonymous by Not applicable
  • 1291 Views
  • 0 replies
  • 0 likes
How to save proper DWG file?
Since I remember every new version of ArchiCAD was promised to be more flexible in exchanging data with AutoCAD, and even with all my practice and obstinacy I still cannot produce 100% satisfactory (accurate) DWG drawing. What I need is: - flattened,...
  • 2217 Views
  • 2 replies
  • 0 likes
GDL Objects from 3DS file
Can anyone tell me why the materials on GDL objects created from a 3ds file render differently to the materials settings? How do I fix or get around this problem? Comments appreciated Scooter ps I have attached an example Notice the stretched image o...
  • 6527 Views
  • 13 replies
  • 0 likes
Sloooow Printing AC10 - Mac OS
Ahh, this is painful. A typical drawing using AC9 will print in... I don't know a couple of minutes....... my first print job in AC10 and it was over 20 minutes (at least it printed ). Any ideas?? I'm using an HP DesignJet 110 +nr
Presentation Drawings
I have 2 sets of floor plans in ArchiCad, one for CD and one for presentation. The pres plans have solid filled walls, but when I import them into PM, they don't show up solid. What setting do I change so that it actually shows what is in my viewport...
  • 2457 Views
  • 2 replies
  • 0 likes
Level Dimensin which i cant delete - AC9
I Have a level dimension on the floor plan which i cant delete. I have moved it off to the side so that i doesnt print. Is there a way to delete it? Other level dimensions are fine, there is only 1 like this. Thanks in advance
teo by Participant
  • 6816 Views
  • 9 replies
  • 0 likes
Print error from 3d window
I have run into a freaky error when trying to print the contents of the 3d window on a MAC... The entire drawing comes out a shaded blue... like a silhouette of the view in all blue.... Hidden line views come out a VERY pale grey even when BLACK & WH...
