Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
missing slabs in fly-through
Hi talkers I have been trying making fly-throughs for a multi-media presentation of a project. At first it worked well, but as the model got more complex, the fly-throughs failed to show slabs, that was modelled as terrain. I did not let the model be...
Anonymous by Not applicable
  • 5543 Views
  • 4 replies
  • 0 likes
Importing 8.0 Teamwork PLC into v3.0 LBK
I am having a problem importing view sets into plot maker 8.0. I have found away around the problem using PLN's, but this doesn't solve my long term needs. If can import a PLN model, but cannot import the DRAFT (PLC) into Plotmaker, is it because the...
  • 3571 Views
  • 5 replies
  • 0 likes
Book Info Quirk
Try this: Open any cheap text editor like Notepad and type three short phrases on three different lines (hitting ENTER at the end of each phrase). Now copy all of this and go into PlotMaker. Select Book->Book Info, then past what you have copied into...
  • 3229 Views
  • 4 replies
  • 0 likes
Help needed
G'day Talkers, I'm in need of some nice curtains for a current project and I was wondering if anyone would have anything available to help me out. File format doesn't really matter (3ds, Obj, DXF). TIA Francois email: power3d@netspace.net.au
  • 6154 Views
  • 5 replies
  • 0 likes
Blank titles
Help! I'm working on a layout for a job and all my PM titles have gone blank! I've checked everything I can think of including re-importing the drawings but the same thing happens. I'm working on a deadline - so this is a bit of a problem! Any ideas?
  • 3909 Views
  • 6 replies
  • 0 likes
Archicad files saved as Artlantis
When I save a rendering from Archicad to Artlantis. I don't seem to be able to open the file. "It says error reading file". I've checked the file and it seems that if I have only show the wall, slab, and roof layers with out furniture layer or the me...
  • 5425 Views
  • 3 replies
  • 0 likes
Sugestions to make a good project with AC8
What is better to do? all the project on one level. or the project on separate levels. and the other question is to make the terrain (site) what is first create on archicad then convert to architerra? or just go direct with architerra? Notes: on the ...
by Not applicable
  • 2500 Views
  • 7 replies
  • 0 likes
Labels
