Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
How to align objects to one edge
Hello again can someone tell me the easiest way to align these three objects. I am after an easier way then grabbing each one. Something akin to align left/right/top/bot as in other software. Maybe one for the wish list but I wanted to check that I a...
Getting to know my sketch engine
This weekend lead to some extended time with my sketch rendering engine and some new (to me anyway) revelations that I felt were worth sharing. 1] The settings of the sketch rendering are significantly influenced by the size & background field in the...
Jefferson by Participant
  • 11946 Views
  • 10 replies
  • 0 likes
missing slabs in fly-through
Hi talkers I have been trying making fly-throughs for a multi-media presentation of a project. At first it worked well, but as the model got more complex, the fly-throughs failed to show slabs, that was modelled as terrain. I did not let the model be...
Anonymous by Not applicable
  • 5547 Views
  • 4 replies
  • 0 likes
Importing 8.0 Teamwork PLC into v3.0 LBK
I am having a problem importing view sets into plot maker 8.0. I have found away around the problem using PLN's, but this doesn't solve my long term needs. If can import a PLN model, but cannot import the DRAFT (PLC) into Plotmaker, is it because the...
  • 3571 Views
  • 5 replies
  • 0 likes
Book Info Quirk
Try this: Open any cheap text editor like Notepad and type three short phrases on three different lines (hitting ENTER at the end of each phrase). Now copy all of this and go into PlotMaker. Select Book->Book Info, then past what you have copied into...
  • 3231 Views
  • 4 replies
  • 0 likes
Help needed
G'day Talkers, I'm in need of some nice curtains for a current project and I was wondering if anyone would have anything available to help me out. File format doesn't really matter (3ds, Obj, DXF). TIA Francois email: power3d@netspace.net.au
  • 6159 Views
  • 5 replies
  • 0 likes
Blank titles
Help! I'm working on a layout for a job and all my PM titles have gone blank! I've checked everything I can think of including re-importing the drawings but the same thing happens. I'm working on a deadline - so this is a bit of a problem! Any ideas?
  • 3911 Views
  • 6 replies
  • 0 likes
Labels
