Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
Trees, People
I've been trying to use the billboard tool. The billboard are placed on the render but they all look transparent in Artlantis 5.5. Wich properties or setting have to be adjusted in order to effectevly rendered the billboard?
Anonymous by Not applicable
  • 3912 Views
  • 1 replies
  • 0 likes
detail border how to get rid of it
Every time I place a detail marker, when i go to that particular detail I get a rectangle around the drawing (which I presume comes from the area of the detail). If I erase it then if I rebuild the detail it comes back. I cannot turn off the layer be...
Accessory Library Suggestions
I would like to know what libraries that one would suggest for accomplishing the mundane things that I have been doing semi-manually. For example: toilet accessory libraries. This is something that we spend a fair amount of time on and to have object...
  • 3609 Views
  • 1 replies
  • 0 likes
Fills Printing as Solid
I am trying to print my first complete set of CD's in PM3.1. All of the fills in my sections and details are printing as solid fills. They look fine on my layout pages in PM. I am printing on a design jet 500. Help Please!
  • 6054 Views
  • 5 replies
  • 0 likes
Archicad 8.1 to plotmaker problem
One of our users is having problem in that when she puts room tags in the .PLN file they do not show up in the plotmaker layout. After you import the drawing into plotmaker there are small empty rectangles where the room tags used to be. Thank you!!!...
  • 5198 Views
  • 4 replies
  • 0 likes
WAS POWERPOINT NOW KEYNOTE
Both programs are on my laptop and bigbox. I like Keynote because the interface is more fluid - creative. Keynote can't do a timed slide show. That is importnt and will arrive soon. Powerpoint is very Microsoft - If you like their other office produc...
Dwight by Newcomer
  • 3774 Views
  • 0 replies
  • 0 likes
Labels
