Document & Visualize forum
Forum Posts
Survey follow-up – Door/Window Detail Level
Dear Community,Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:https://community.Graphisoft.com/t5/Document-Visualize-forum/Doors-amp-Windows-Detail-Levels-within-a-single-drawing-1-minute/m-p/33...
align add drawing in layout
how do i align the drawings in the layout? the pencil cursor doesn't seem to pick on the other added drawings. please help. print- i am using fineprint2000 for 24 x 36 paper size. i see there is a smaller blue rectangle within a large red rectangle w...
Anonymous by Not applicable
  • 15794 Views
  • 10 replies
  • 0 likes
relinking broken links to a pln/plp viewset
anybody know if this can be done? I accidentally broke the links to an lbk that I wanted to archive before making the copy to continue building upon. now all my drawings are embedded pmk's and I can't link them back to my original plp viewset. if the...
  • 7658 Views
  • 6 replies
  • 0 likes
printing file
is there anyone here, send their archicad drawing to a repro to print their drawings? what file type did you send? xphome/ac7r3
  • 5190 Views
  • 4 replies
  • 0 likes
textures go mad.....:(
Hi! When I render my very large model in ArtLantis 4.0 som of the wall panel images I attach to tha walls show up differently on different walls even though the material is exactly the same....please help me out! See the attached image...It seems lik...
  • 8015 Views
  • 5 replies
  • 0 likes
OUTPUT TO ARTLANTIS IN 8.1 WARNING MISSING
THERE WAS A TIME WHEN ARCHICAD WOULD WARN YOU IF YOU TRIED TO OUTPUT A FILE TO ARTLANTIS WITH NO LIGHTS. I WAS STUPID ENOUGH TO DO THIS IN 8.1 JUST NOW AND DIDN'T GET THE WARNING. IT WAS A BIG HASSLE TO SEND THE FILE BACK TO VERSION 8.0 TO FIND OUT T...
Dwight by Newcomer
  • 4180 Views
  • 1 replies
  • 0 likes
Trees, People
I've been trying to use the billboard tool. The billboard are placed on the render but they all look transparent in Artlantis 5.5. Wich properties or setting have to be adjusted in order to effectevly rendered the billboard?
  • 3919 Views
  • 1 replies
  • 0 likes
detail border how to get rid of it
Every time I place a detail marker, when i go to that particular detail I get a rectangle around the drawing (which I presume comes from the area of the detail). If I erase it then if I rebuild the detail it comes back. I cannot turn off the layer be...
Accessory Library Suggestions
I would like to know what libraries that one would suggest for accomplishing the mundane things that I have been doing semi-manually. For example: toilet accessory libraries. This is something that we spend a fair amount of time on and to have object...
  • 3614 Views
  • 1 replies
  • 0 likes
Labels
