Document & Visualize forum
camera angle
every time i want to bring up a 3d view of any floor
it always just comes up with the ground floor????
how do i fix this
thank you
8 REPLIES 8
Scott Bulmer
Could you please list the steps you take in projecting the model? Are you on the first story & select only the elements on that story, then project? If so, that's all you'll get. To get the whole enchilada you need to have either nothing selected when you project, or multi-story (dark marching ants) marquee around the area to be projected. Also check View>Elements in 3D View>Filter Elements in 3D to make sure you have not constrained the projection to your first story only.Hope that's what you're looking for.
Scott
AC25 v. 5005 w/ MEP, Cadimage, Twinmotion 2021 using AC from AC6.0, 2.7 GHz 12-Core Intel Xeon E5 (OS X 12.2.1 Monterey), AMD FirePro D700 6GB, SSD, Artlantis 2019, Adobe CC. Used AC on both platforms.
when i go onto perspective settings i can seen the 2nd floor which is DARk
then the ghost view of the 1st floor below it
i set the angles sun etc then press ok for 3d mode and the 1st floor comes up not the 2nd
not sure what im doing wrong here
Djordje
Mentor
screenshot please?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
sniperpirate:
Please also post which version of ArchiCAD you are using. The options for controlling what appears in the 3D Window have changed between versions 9 and 10.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
i am using version 9
i will try post a screen asap
Aussie John
is your camera elevation set to be in the 2nd Storey?
Cheers John
[/size]
Scott Bulmer
It looks from your screenshot that the camera may be inside the building for an interior shot. If that's the case and all you're getting is the first story then you need to raise the camera 'Z' height and target settings in the camera settings DB.
yes in the picture it is of the 2nd floor
and ill try moving the z angle thx
