Visualization
cineRender by Maxon add-on unexpectedly closed.
mi_jan
Everytime I Render a view it starts calculating the cgi and then it gets stuck at preparing 5.6%, eventually it says its finished but its not. When I open up render settings again I get the following error message
"Warning, cine render by maxon add on has unexpectedly close Archicad should be restarted. "
p.d. It happens with the custom rendering scene I have been using for the past year and also archicads default render scenes
I can't render at all, the preview comes out in the render settings window but the actual image does not. I tried Marquee with several areas of the project but still no luck.
iMac - MacOs Big Sur 11.6.6
Archicad 24 - Latest Build
Archicad 25 - Latest Build
14 REPLIES 14
derekjackson
Thanks, but the marquee trick doesn't work. I even have issues with blank files, so it seems to be independent of the model content.
Erwin Edel
Tried a reboot I assume?
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
derekjackson
Many times!
Pato99
Just chiming in here.
I've had this issue on AC20 for a while now. I don't think it's a ram issue, I've got plenty and it happened one day out of the blue, then started a few month later on my laptop.
I've been getting around it by hitting render (getting failed render) then as quickly as possible re-rendering. It seems cinerender takes too long to start but once it's running you can jump on the back of that last startup.
Personally I think due to a win 10 update, hence the delay of the issue between devices. Re-install of software should fix the issue, but this workaround works for me at the moment.
Versions 10 to 27
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
Hi everyone,
I know this is an odd solution - I can't explain why it worked, but for me it did and maybe it'll help someone else out too.
I kept getting the same "cineRender by Maxon add-on unexpectedly closed" error message, and tried EVERY suggested solution I could find (including totally uninstalling and Archicad and re-installing) and nothing worked.
But then I had a weird idea and....
....I turned my VPN off.
Voila! It started working working immediately and has worked ever since!
Hope this helps save someone else from going through what I went through today!
Cheers!!
