custom classification
Bara3
Hello, I would like to add a custom classification to my windows and custom-write f. g. colour of the frage, material and so on, but I Achicad always offers me only a choice from certain possibilities. Is there a way how to change the choice or how to type there my own custom text? I want to put it in there, so I see it correctly in my schedules.
Thank you.
Miha_M
Go to Options menu > Property manager and search for Barva ramu. It is probably on Option set type, where you can edit the pre-set options.
In the Property Manager you can also add new custom element properties. Just make sure they are mapped to correct Archicad Klasifikace -v.2 instancies.
| Archicad 4.55 - 27
Miha_M
| Archicad 4.55 - 27
yes! properties are great for schedule fields... so much better than the "custom text" bit we used to have to use!
Thank you, it worked perfectly.
