Visualization
dichroic glass material
Pato99
Hey Guys,
I'm a bit stumped on producing a dichoric glass material. I'v tried a few things but it's just not working.
I'm hoping someone could give some direction on how this could be done. I know Lumion so I would suggest it's achievable.
Here is an example: http://picssr.com/tags/chameleonlab/page3
This might give some hints:
Thanks for any help!
Versions 10 to 27
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
Erwin Edel
Just an idea: fresnel shader, you can set two colours for the gradient, should change colour depending on your viewing angles? Just put it on the 'color' channel.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
Did a quick test with transparant and just reflective material, not as striking as your examples, but I think you might get some results out of this.
www.leloup.nl
Windows 10 Pro
