hotfix pls for for AC12 "paper sizes not selectable"
I was going to post this on "wishes" but could find the right category...
Can GS please issue a hotfix for AC12 as they did for AC13 (hotfix 2 build 3235) which fixed the grayed out paper size options when trying to print.
I switch back and forth between an HP 110+nr and an HP 2840 for A4 documents...it's a real pain when you just want a screen print and don't want to go through Publisher (make a view, place on Layout, save as PDF) and then print though the PDF viewer. This takes time (and every minute counts sometimes); also the file size increases with every view saved and "laid-out".
Thanks
5 REPLIES 5
I know this is a work around you shouldn't have to do but it might help.
Save two (or more) versions of your printers each with a different default paper sizes.
Give them approprate names like HP110-A3 and HP110-A2.
Then when you print just choose the one that suits your drawing paper size.
Or am I mis-understanding the problem.
I have no trouble choosing paper sizes - on PC in version 12.
Thanks Barry that's a great idea - I'll tell you if it works.
...and I believe it's a Snow Leopard on Apple Mac problem only - it was working fine with the previous OS...
Regards
Moji
Rod Jurich
Moji wrote:
/...........and I believe it's a Snow Leopard on Apple Mac/...
Moji, that is correct.  Snow Leopard/ArchiCAD issue.
Fixed in latest 13 hotfix, but anybodies guess if GS do likewise for 12.
Keen to see if Barry's tip works for you.
Rod Jurich
...it doesn't work as I don't have the option of anything larger than an A3 on the printer set-up from system preferences window, and yet all are shown (whether grayed or not) on the page setup in Publisher on AC12.
I guess I can set up an A1 using the manage custom sizes from print menu in AC...not ideal but it should work.
Thanks again
Thank you Graphisoft for the Hotfix!!!
