2003-11-12 03:30 AM
2003-11-12 07:32 AM
otylyka wrote:You can't.
how could i select more than one lights and change the settings just one time for all?
2003-11-12 08:42 AM
2003-11-12 09:06 AM
Djordje wrote:It might even be found from a non-French user ...but perhaps I repeated his/her tip.otylyka wrote:You can't.
BUT - you can, by editing the DB file in the text editor. There was a tip by a French user on the old Talk, it probably can be found on the eScribe.
2003-11-12 09:30 AM
2003-11-12 02:17 PM
archibaldo wrote:
P.S. if you want to activate the special menu in artlantis you must do this :
in edit shaders menu window keep press SHIFT and in the same time type the next text
((EXPERT)
and you will see a most complex shader editing menu
to activate another special hidden shader menu you can
tipe a second command
((MNSHADER)
2003-11-12 02:20 PM
2003-11-12 11:28 PM
Shaun wrote:Only for the Italian-speaking ones.
I'm obviously missing something somewhere: could you explain it again for a moron?
2003-11-13 04:03 AM
Karl wrote:... and the URL is ... ?
2003-11-13 04:10 AM
Djordje wrote:otylyka wrote:You can't.
2003-11-13 11:03 AM
2003-12-05 06:43 AM
archibaldo wrote:Good tip,
if you press CTRL in artlantis (in the creating new light window )the next light created will have the same settings with the previous
((EXPERT)
((MNSHADER)
2003-12-05 11:37 AM
archibaldo wrote:Archibaldo,
be carefull NOT to edit in the text processor (uedit.32) even the
artlantis.exe file or TXTEXTENSION file
