lines show in plan of slab joints with the same materials
heathldesign
i have two slabs of different thickness that are adjacent, made from the same material. in plan view there is a line at the join. this is problematic for construction documents. so how do i hide the join?
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC26 5003 Apple Silicon USA
heathldesign
anybody shed some light on this?
Eduardo Rolon
AC does not clean up the joints between slabs on floor plan (longstanding wish) so you are not doing anything wrong. The usual solutions/work arounds are to
• Turn the slab layer off for floor plans (recommended)
• Draw a white line or white fill over the joint
• Use GOs to override the uncut pen for those slabs (have not tried it)
AC floor plan views are not a projection.
You have found one of the annoying little items in AC for which all users have their workarounds.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
heathldesign
Thanks for this, i'll put my two cents worth in the wish list.
