I have publishing sets per file type / printing.
You can rename items if you right click a folder or just the whole project in the publishing set, just add the autotexts you like. This will rename all items in the publishing set.
We use a custom text field in our change manager for identifying different change dates. The only thing it doesn't work on is renaming folders that are used to unify several layouts to one PDF/DWG (in the case of detail booklets, for example).
The autotexts from the Issue list will only change on layouts for that issue. So let's say you have a set of 5 layouts. 2 of these are changed in the next issue, only these 2 will have their name changed, the other 3 stay based on the previous issue.
www.leloup.nlArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
