Visualization
"Picture 14" custom image display problem
muzedesigns
Hello!!
In my project I have used the "picture 14" object with custom images in several different locations.. However, for some reason, when rendering in Lightworks.. the picture objects with rotation of 90° rendersing the images correctly however those with a rotation of 0° the custome image is hardly visible..
Does anyone one have any advice - What am I doing wrong
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
5 REPLIES 5
Dwight
I tested the element and find no problems.
Perhaps you should consult a priest.
Dwight Atkinson
David Maudlin
Chrissy:
Are you sure that the pictures are not facing the wall?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
muzedesigns
Hi Guys.
Yes I am positive the are not facing the wall.. each picture has the same material - I drag a copy and rotate..
Chrissy Avramidis
muzedesigns
I have just downloaded Dwight's Parapicture and this works perfectly so am going to use this instead - saved the day again Dwight!
Thank you both for your help, as usual
Chrissy
Chrissy Avramidis
muzedesigns wrote:
Hi Guys.
Have you tried just rotating these a further 180°?
There was a post recently abiut the Picture 14 object where we discovered they have put a backing board in iot so the image can't be seen from behind.
http://archicad-talk.graphisoft.com/viewtopic.php?p=178021&highlight=picture#178021
