Find the next step in your career as a Graphisoft Certified BIM Manager!
Visualization
"View from Sun." Is it possible?
Rob
I need to create solar access diagrams that show views of a building as if you were looking from Sun. I just wonder if anybody knew how to create that.
So far my findings are:
obviously we can use altitude and azimuth of Sun provided by AC however
1. you can't use perspective view as you would have to place the camera target individually on each window glass pane.
2. axonometry views - I am not sure how I can calculate Sun's altitude... or is it geometrically impossible with this kind of projection?
Anything that could point me to a right direction would be appreciated.
Thanks.
::rk
How is your GDL Rob??
I'd create an object that had a center point (mid house) and then
listed a z height out at a given radius and places a simple 2D x to position the camera on. This would be done with the GLOB_SUN_AZIMUTH and GLOB_SUN_ALTITUDE and some trig that I cant fathom at this moment in time!
27hrs without sleep sitting in an airport lounge in Auckland will do that to you though!
It will still be time consuming though as you will have to place a camera for every time/date combo you use.
Hope that helps
Rob
Kristian,
my GDL is brilliant, sometimes I talk to my boss in this language
this is wrong assumption mate I have been a victim of too. Perspective does not work in this case with AC as it works with the target point.
In meanwhile I have managed to work it out, sort of. I came to realisation that when you are looking from Sun you can't see any shadows. So I used axonometry plan view rotated by azimuth and then manually lifted camera till all shadows were obstructed by building structures (so the altitude was right). Not really Computer Aided Design approach though but I got what I wanted.
we simply take drugs here. it is more convenient and faster.
::rk
Set the controls to the heart of the sun? (Pink Floyd)
