Document & Visualize forum
"walhole" not working
archigreen
For some reason the "WALHOLE" comand is not working to make custom wall openings. Where can one chose, eg. slab, to be editable or not?
ArchiCAD 20
iMac Mac OS X Sierra 10.12
4 GHz. Intel Core i7
16 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
2 ACCEPTED SOLUTIONS
If you are assigning a slab in the floor plan as "WALHOLE" then save it out as a window or door, your spelling is the issue.
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Yes, the ID of the Slab must be "WALLHOLE" with 2 "L" characters, not with 1 "L".
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
5 REPLIES 5
Can you share the part of your code where you are using "WALLHOLE" so the issue can be evaluated?
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
AC18-23 AUS 7000
archigreen
Thanks, Laszlo
My bad. It used to be with one L long time ago. I guess I am getting old.
ArchiCAD 20
16 GB 1867 MHz DDR3
+1 IDE update w/ autofill.
AC18-23 AUS 7000
