structure label - text order
Hello!
I have a problem with labeling walls with structure label.
When I set it to show skins and its widths archicad first shows width and then skin name.
It should be the other way around. Is it possible to change it?
If the parameter settings don't allow the change it would require editing the script.
I thought so, and even opened script, but I think this is something that requires some advanced GDL scripting skills.
