wall intersection troubleshooting
i have a number of wall intersections that are not intersecting. i have
done the following:
checked to ensure the wall reference lines are on the same side
wall heights (some walls vary in height but not many)
adjusted the tolerance levels
any thoughts............
thanks!
ky -
archicad 11
1 REPLY 1
Check the layers the walls are on, and that the layers (if more than one) have the same intersection priority, or if they are all on the same layer that its intersection priority is not 0 (zero).
(Intersection priority is the column to the left of layer name in the layer dialogue)
