2017-11-08 09:09 AM
2017-11-08 04:44 PM
2017-11-08 07:40 PM
nancylee wrote:Did you check Floor Plan Display Options ?
drawing up a new plan in Archicad 20, which I'm still learning, and the walls are drafting in as gray and not cyan.
- walls on correct layer
- cyan is selected as the line color
- cut plane set to 3'-6"
the only way to make the walls show up cyan is to make the wall start 3'-1" below the floor level.
ArchiCAD 25 5010 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
2017-11-09 08:29 AM
2017-11-09 08:43 AM
2017-11-09 04:40 PM
