Read articles about Archicad's documenting tools, views, model filtering, layouts, publishing, etc.
Articles
Improvements of the Level Dimension Tool
Level Dimension text content was hard to customize The Level Dimensions update in Archicad 26 focuses on avoiding repetitive tasks to save time on creating documentation. These new functions requested by our users make using this tool faster and more...
EmokeCsikos_0-1654014302607.png EmokeCsikos_1-1654014302621.png EmokeCsikos_2-1654014302639.png
Site Plan in Archicad
Note: The steps described in this article are still applicable for the latest version. The expected outcome of site plan as per the Singapore standards are achievable only by the workaround given in the article. Site plan shows Plan of the buildings ...
Under the hood: 2D rendering in Archicad 26
This article aims to provide some insight into our 2D modernization project spanning across multiple Archicad versions. The focus will be on the changes in line rendering and its benefits. As the title implies, the material is recommended for readers...
Stair flight numbers in section
There are two ways to label stairs in a section: manually (one by one) or automatically. The manual way is to use the Label Tool, find the Stair Riser Step Index and Stair Tread Step Index from the favorites, which are included in the default Archica...
wp-content_uploads_2018_08_man_label.gif wp-content_uploads_2018_08_automatic_label.gif
Pen Sets
NOTE: the available Pen Sets and their parameters can be different in every language version. In this case, this PEN SET theory doesn't apply to the U.S. version The Pens and Colors Settings Dialog is available in Options > Element Attributes > Pens ...
Info_18x18.png wp-content_uploads_2017_11_Pen-Set-table.png wp-content_uploads_archicadwiki_pen-sets--built-in_pensets.png wp-content_uploads_2017_11_columns-and-rows-1024x646.png
New Autotext Options for Master Layout and Subset Information
Autotext on Master Layouts is an intelligent Archicad tool that automatically updates documentation-related information in title blocks. However, users needed to add manual text, place specific autotexts for each subset in the Layout Book, or create ...
Quick Tip – Expand and Collapse All
Got a huge amount of folders in your View Map and/or in the Layout Book and want to see all their content expanded? Select the folder and use: ALT+right arrow (MAC) and * (Windows) to expand all within the selected folder ALT+left arrow (MAC) and – (...
Quick Graphical Quality Checks with Archicad
With the improved Graphic Overrides now RGB colors can be selected for Background Fill Pens and 3D surfaces in Graphic Override rules. This way, you do not have to create separate pens and surfaces with a specific color to highlight elements if you w...
Create a Copy When Stretching Circles
User interactions should behave consistently and with expected results The behavior of the radial stretch command for curved elements, for versions previous to Archciad 26, could be more consistent. It left a gap in the user’s workflow when working w...
Easier Management of Graphic Override Combinations
Find and add a rule to a combination When creating Graphic Override Combinations, it can be time-consuming to find and add only one rule at a time to a combination. Now you can perform tasks faster — Graphic Override Combinations let you add multiple...
GabrielDantas_0-1653304822537.png GabrielDantas_1-1653304822540.png GabrielDantas_2-1653304822542.png GabrielDantas_3-1653304822544.png
Improved PDF Import
Import multiple PDF pages at once Importing external content in Archicad is handy for placing external information such as PDF documents in Viewpoints or on Layouts. Until Archicad 26, it was only possible to import one PDF page from the same selecte...
lewaa_ab Graphisoft Alumni
  • 6152 Views
  • 0 comments
  • 3 likes
Design Concept Presentation with Archicad
In this article we want to provide some tips and tricks to supplement or enhance architectural drawings. Architects need enhanced architectural drawings to be able to represent their design concept efficiently. Of course, you have to start with a pro...
wp-content_uploads_archicad-23-reference-guide_130_userinterfacedialogboxes_ParallelProjSets.png wp-content_uploads_2020_01_custom_axonometrx.png wp-content_uploads_2020_01_Top_Axonometry.png wp-content_uploads_2020_01_Isometric_Axonometry.png
Altitude and Reference Levels for Singapore BIM Submission
Note: This article was originally published on AsiaBIM and was written for Archicad 19 mainly for architects working on the Singaporean market. Setting up the Project Altitude properly and displaying its values for BIM Submission in Singapore require...
Level Dimensions and Gravity
See also: http://www.cadalyst.com/aec/how-display-elevation-values-relative-sea-level-archicad-insights-tutorial-3714 Level Dimensions Level Dimensions are point-level elevation markers common to architecture and site planning. They measure the eleme...
wp-content_uploads_archicadwiki_leveldimensionsandgravity--changeleveldimtext.png wp-content_uploads_2016_06_Info_18x18.png
automata Graphisoft
  • 2877 Views
  • 3 comments
  • 0 likes
Updating Rendered Views on Layouts Automatically
A quick way of keeping your rendered images up-to-date without re-rendering them manually after changing the model is to use the 3D Only panel of the View Settings. Instead of rendering the specific camera views, then saving and placing the final .jp...
screen-shot-2016-02-12-at-12-53-56.png screen-shot-2016-02-12-at-10-57-56.png
Decimals and Digit Grouping
Ever wanted to change how the numbers appear in Archicad, but could not find the settings in the Dimension Preferences? By default all numbers are showing commas for digit grouping and full stops for decimals. This can be very easily changed in the s...
Labeling IDs of Surfaces and Building Materials
Since there is no perfect solution for labeling an abbreviation (ID or code) of elements, mainly the Surfaces, two main ideas emerged other than using external label objects: use Labels along with Properties or IFC mapping. Though the first may seem ...
screen-shot-2017-02-02-at-14-00-46.png screen-shot-2017-02-02-at-17-19-12.png screen-shot-2017-02-02-at-16-35-47.png screen-shot-2017-02-02-at-16-54-59.png
Transparent Textures and Vectorial Hatchings in 3D Documents
Transparency and Vectorial Hatches ( renamed as Surface - Cover Fill Foreground in AC 25) are some nice features of the 3D Documents, so the wish of combining these two for a single surface at some point (for example displaying mesh-like surfaces) is...
Bird’s Eye View of a Building to be Placed in Master Plan
There are times when you need a Drone view of the building to show in Master Plan. All you need is the outline of the building, but it takes a lot of time to get a clean and crisp overall boundary of the entire project. And, in case there are updates...
Using Expressions to Label Partition Types
With the introduction of expressions in ARCHICAD 22 users can extract and manipulate information from the model. Follow the steps below to learn how to take the name of a composite and abbreviate it for use in a partition tag. 1. Go to Options > Comp...
wp-content_uploads_2019_03_Screen-Shot-2019-03-04-at-8.55.10-AM.png wp-content_uploads_2019_03_Screen-Shot-2019-03-01-at-2.46.34-PM.png wp-content_uploads_2019_03_Screen-Shot-2019-03-01-at-3.11.10-PM.png wp-content_uploads_2019_03_Screen-Shot-2019-03-01-at-3.09.30-PM.png
Show Projection Settings
The origin of this tip is a blog post by Pablo Montes on his great blog, Arquitecturama.MX: http://juanpablos.blogspot.com/ There are three options can be set as Range of Element’s Projected Display definition (Show Projection) for a non-straight Wal...
wp-content_uploads_archicadwiki_wallfloordisplayshow--01.jpg wp-content_uploads_archicadwiki_wallfloordisplayshow--02.jpg wp-content_uploads_archicadwiki_wallfloordisplayshow--3.jpg wp-content_uploads_archicadwiki_wallfloordisplayshow--4.jpg
automata Graphisoft
  • 1728 Views
  • 1 comments
  • 1 likes
Using Partial Structure Display for Structural Connection
In the AEC industry it is a daily demand to architects to be able to present, display and export their architectural models simplified or filtered in certain ways. Cooperation with structural engineers usually require a structural model. There are se...
wp-content_uploads_2018_01_Properties-2-2-300x215.png wp-content_uploads_2017_01_psd.png wp-content_uploads_2017_01_structure-options-1.png wp-content_uploads_2017_01_core-skin-in-composite-1024x333.png
What does Open and Repair repair?
Open & Repair is one of the most useful commands in Archicad, it is the solution to many common issues. The purpose of the repair process is to physically fix damaged files. When the damage occurs, one or more parts of the file become corrupted or lo...
Autotext Annotation
See also: How to Insert Autotext in ARCHICAD Help. The ProjectInfo database can be used as a location for stored annotations. These annotations can be then inserted into the project with AutoText. If you work on a plan where the annotations belongs t...
wp-content_uploads_archicadwiki_autotextannotation--01.jpg wp-content_uploads_archicadwiki_autotextannotation--2.jpg wp-content_uploads_archicadwiki_autotextannotation--3.jpg wp-content_uploads_archicadwiki_autotextannotation--4.jpg
How to Fillet/Chamfer a Polyline
This is one of those handy tips can save a lot of time to newcomers. Instead of the tedious job of exploding your polyline to fillet with arcs, follow the below steps: select the polyline pick a corner node (not along a section of line) left-click on...
automata Graphisoft
  • 2532 Views
  • 0 comments
  • 1 likes
Viewpoints getting deleted in Archicad 24
Affected versions: Archicad 24 | Severity: Fixed in an update | ID: DEF-3085 We have discovered a regression issue with Archicad 24 Update 4007, Archicad 24 Solo Update 4004 and the Archicad 24 Releases of the CHE, CHI, GRE, KOR, TAI and UKR versions...
Extracting Contour Lines (Isolines) of a Terrain
Occasionally you may want to generate a contour map of the terrain of your project. The 3D terrain can be imported from an external source, thus can be an object or a morph in ARCHICAD or can be a mesh created in ARCHICAD. The default Floor Plan repr...
wp-content_uploads_2019_09_mesh-and-isolines-1.png wp-content_uploads_2019_09_Settings_correct.png wp-content_uploads_2019_09_Contour_correct.png wp-content_uploads_2019_09_different-density-1.png
How Do I Set the Path for Publishing Only One Layout
In order to set up the path for only one layout, you have to set the path for the whole set, because the publishing path can be defined only on the level of the sets. To accomplish this there are two ways: The first way: Go to the Publisher Sets in t...
wp-content_uploads_2019_04_Publisher_set__1.jpg wp-content_uploads_2019_04_Publisher_set__2.jpg wp-content_uploads_2019_06_no-path-defined-300x132.png
How to create a custom Fill
To create a New Fill, you need to open Options/Elements Attributes/Fills panel. There you can edit all the existing Fills and add new ones. By clicking on the New... button you get the choice to create a new Solid fill, a new Symbol, a new Image Fill...
wp-content_uploads_2018_09_path.jpg wp-content_uploads_2018_09_Create-a-new-Fill.jpg wp-content_uploads_2018_09_Custom-Fill-pattern.jpg wp-content_uploads_2018_09_New-Fill-edit.jpg
Lines in PDF not connecting properly on macOS 10.14 Mojave
Affected version(s): All | Severity: Not our Bug | ID: 257211 Issue When you open a vectorial PDF (e.g. a drawing saved from ARCHICAD) in the Preview application on macOS 10.14 Mojave, the connection of the lines might not be clean. Solution This is ...
Font and Paragraph Styles – Using Favorites for Texts
Similar to how font and paragraph styles work we can create and store favorites for Text Styles in ARCHICAD. What are Text Style favorites? First of all, what settings do Text Styles contain? We can customise the following settings: Using these setti...
Importing and Exploding PDFs
Often times a PDF is the only file type available for certain content. Fortunately ArchiCAD allows you to import and convert the vector information into usable elements. Please follow the steps below to import and explode PDFs in ArchiCAD. Importing ...
wp-content_uploads_2018_10_Screen-Shot-2018-10-19-at-12.48.37-PM.png wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2018_10_Screen-Shot-2018-10-19-at-12.50.51-PM.png wp-content_uploads_2018_10_Screen-Shot-2018-10-19-at-12.53.51-PM.png
How to display hidden Mesh lines on a section
How do we make a mesh cut line in section dashed? - asked by nickATA on ARCHICAD-TALKOne of our users posted this question on ARCHICAD-TALK about how to make an uncut line of a Mesh dashed on a section. The situation described was with two meshes (on...
wp-content_uploads_2018_10_section-300x111.png wp-content_uploads_2018_10_3d-document-300x99.png
Trace & Reference Palette
Trace image not aligning across Stories - asked by John on ARCHICAD-TALKSometimes we can run into issues with Trace & Reference: the ghost drawing is shifted, not aligning with the content of the stories above certain elements missing from the ghost ...
wp-content_uploads_2018_10_trace.jpg wp-content_uploads_2016_06_Info_18x18.png
How to enable Shadows and Hatching in Elevation and Section
ARCHICAD allows users to quickly apply hatches and shadows to elevations and sections. To enable shadows and 3D vectorial hatching, please follow the steps below. Navigate to Elevation or Section. Open the Elevation (or Section) Settings dialogue box...
wp-content_uploads_2018_10_elevation_view-1024x520.png wp-content_uploads_2018_10_Elevation_Settings-300x213.png wp-content_uploads_2018_10_shadow_elevation_setting.png wp-content_uploads_2018_10_elevation_view_with_shadows_and_hatching-e1539072144930.png
About Fills
Fills are geometric 2D hatching patterns that help you distinguish and decorate the elements of your project. They can also be used to decorate surfaces in the 3D window and the 3D Documents. ARCHICAD comes with a full set of Fills that are available...
Exporting to a 3D Printer using an STL file
One of the advantages to modeling in 3D is that the project file can be easily exported to a 3D printer using the STL (StereoLithography) file format. Follow the steps below to export the model as an STL. Readying the Model for Export 1. Open the mod...
wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-11.38.04-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-11.38.39-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-11.40.29-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-12-at-11.40.40-AM.png
How to change the dimensioning units by view
Is it possible to set two dimensioning methods in ARCHICAD in one project? - asked on FacebookThis question can be interpreted many ways, let's summarise what we know about dimensioning, what we can and can't do. Setting up the units in the project F...
Expression-defined property labels
What is an expression? An expression is a mathematical phrase which combines numbers, variables and operators to show the value of something. Being introduced in AC22, expression-based properties can come in hand when we want to create custom propert...
wp-content_uploads_2018_07_labels-1.gif wp-content_uploads_2018_07_Screen-Shot-2018-07-03-at-16.47.17.png wp-content_uploads_2018_07_sequences-2.gif wp-content_uploads_2018_07_Screen-Shot-2018-07-03-at-14.09.20.png
How to place Angle Dimensions in ARCHICAD
The Angle Dimension tool can be found in the toolbox palette, under the “More” group of tools: Angle Dimensions display angle values: between a pair of lines or linear edges or the angle of a curved element NOTE: Angle dimensions are not available in...
wp-content_uploads_2018_06_Capture-129x300.jpg wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2018_06_possible-units-234x300.jpg wp-content_uploads_2018_06_methods.jpg
Dimensioning issue with Composite Walls
Affected version: 22 | Severity: workaround applicable | ID: 247461, 248282 Issue: When migrating a project to ARCHICAD 22 Build 3004, in Composite Wall corner situations Dimensions placed to one layer of the composite might jump to another layer of ...
wp-content_uploads_2018_06_dimension-witness-line-change-in-archicad-22.png wp-content_uploads_2018_06_automatic-dimensioning-core-faces.png
Floor Plan Display with Overhead
ARCHICAD construction elements on a floor plan usually can have 3 different displays. projection projection with overhead cut only Using Projection with overhead is a similar look for different element types: There are a few exceptions though, having...
Line types displayed across stories
In case we would like to show our elements on other stories as well, one might wonder where to set the line type for the display one story above or below? In case of three basic elements, slabs, objects and meshes, we can set this under Project Prefe...
wp-content_uploads_2018_05_Screen-Shot-2018-05-29-at-16.17.46.png wp-content_uploads_2018_05_Screen-Shot-2018-05-29-at-16.16.34.png
Grid Elements in Elevation or Section
The Grid Tool in ARCHICAD allows elements placed in plan view to show in Elevation and Section. Enabling Grid Elements in Elevation or Section Select the elevation or section in the project map and click the settings button. In the Elevation/Section ...
wp-content_uploads_2018_12_Screen-Shot-2018-12-18-at-11.04.34-AM.png wp-content_uploads_2018_12_Screen-Shot-2018-12-18-at-10.52.46-AM.png
PDF Tips & Tricks
There are many ways to make use of vectorial PDFs in ARCHICAD. Below You can read about are the most commonly used features and tricks. Saving PDFs from ARCHICAD You have two options to save PDF from ARCHICAD: Publish You can also publish PDF documen...
Printing problem with transparent fills
Issue Fills are not printed correctly via the File-Print menu or from printing via the Publisher Dialogue box. Some part of the fills are missing, see examples: Cause When transparent solid fills (also known as "percentage fills") overlay other fills...
wp-content_uploads_archicadwiki_bugs-printingproblemwithtransparentfills--vegleges001.jpg wp-content_uploads_archicadwiki_bugs-printingproblemwithtransparentfills--vegleges003.jpg wp-content_uploads_archicadwiki_bugs-printingproblemwithtransparentfills--3.jpg
Entire Schedule/Index appears as solid colour in Layout
Affected version(s): 20 | Severity: workaround applicable | ID: 224455 Issue In certain cases, placed Schedule/Index on Layout appears as solid colour. Cause The issue occurs if Background Pen of the Fill tool is set to RGB colour (Colour of schedule...
wp-content_uploads_2017_03_issue-243x300.jpg wp-content_uploads_2017_03_cause.jpg
Visual Compare - Trace & Reference
Introduction This feature helps the user identify the differences between two views. All the necessary settings are available from the Trace and Reference Palette which is accessible from the Window > Palettes menu. Main options of the Trace & Refere...
wp-content_uploads_2007_06_t-and-r-palette.png wp-content_uploads_2017_02_browse2-1024x510.png wp-content_uploads_2017_02_colors.png wp-content_uploads_2017_02_01.png
Creating Custom Plotter Drivers
Introduction There is a large number of .xml files called plotter drivers shipped with ARCHICAD. They are located in a folder named PlotWare within the main folder of ARCHICAD. These files contain some basic information (e.g. maximum paper size, size...
wp-content_uploads_2017_01_folder-1024x471.png wp-content_uploads_2017_01_plot-setup-681x1024.png wp-content_uploads_2017_01_text-file-968x1024.png wp-content_uploads_2016_06_Info_18x18.png
2D Modeling/Editing - Troubleshooting Guide
Incorrect cursor and feedback position in case of offsetting edges or nodes of polygonal elements or placing dimensions Affected version: 19 | Severity: workaround applicable | ID: 199288 Note: We fixed this issue in ARCHICAD 19 Update 4013 Issue: Wh...
wp-content_uploads_2014_10_offset_edge.png wp-content_uploads_drag-multiple-copy-with-shortcut.png wp-content_uploads_drag-multiple-copy-context-menu.png wp-content_uploads_archicadwiki_bugs-guidelinesmousedown--simple_70.png
PlotMaker
PlotMaker was a layouting program that was part of the ARCHICAD package. This standalone application was optimized to prepare an architectural documentation set based on the views, drawings and images created in ARCHICAD. PlotMaker could also accommo...
Damaged or Incomplete PDFs Published to Server
Publishing PDFs from Mac OS X to a server may result in damaged or incomplete files Affected version: 18, 19 and 20 | Severity: workaround applicable | ID: 210554 Issue When you view these PDFs you see one or all of these: The PDF viewing application...
wp-content_uploads_2014_10_2016-05-30_1546.png wp-content_uploads_2014_10_2016-05-30_1544.png
PDF - Troubleshooting Guide
PostScript fonts are not displayed Affected version: 18| Severity: workaround applicable | ID: 177770 Note: This issue was fixed in ARCHICAD 19 release version. Issue PostScript Fonts are not displayed in PDFs, that are published from ARCHICAD 18 on ...
wp-content_uploads_pdf_windows_trouble1-300x102.png wp-content_uploads_archicadwiki_bugs-calibrifontprobleminpdf--calibriletters.png wp-content_uploads_text-collapse-after-print-with-adobe.png wp-content_uploads_print-as-image.png
Fonts/Characters - Troubleshooting Guide
Postscript Fonts are not displayed in PDF For this issue, please see the PDF Troubleshooting Guide Special Characters on Mac Affected version: 16 | Severity: workaround applicable | ID: 158311 NOTE: This issue was fixed in ARCHICAD 17 release version...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_archicadwiki_bugs-specialcharactersonmac--language-text.png wp-content_uploads_archicadwiki_bugs-cyrillicfontproblems--01.jpg wp-content_uploads_archicadwiki_bugs-cyrillicfontproblems--x1.jpg
ARCHICAD 18 Revision Tool troubleshooting guide
Revision History library object, line spacing issue Affected version: 18 | Severity: no workaround applicable | ID: 172837 Note: This issue was fixed in ARCHICAD 19 release version. Issue The line spacing of the Revision History object is lofty if on...
wp-content_uploads_images_Screen-Shot-2014-06-20-at-15.49.03-e1403272231414.png wp-content_uploads_images_Screen-Shot-2014-06-20-at-15.55.03-e1403272528966.png
Missing elements - Troubleshooting Guide
Missing Elements in 3D (and 2D) Views If you notice missing elements or a blank window, the following possibilities are worth to check: 3D There is no missing macro in libraries (this sometimes aborts model creation) No 3D cut plane is turned on (Vie...
wp-content_uploads_archicadwiki_bugs-elementsnotvisiblein3d--renovation.png wp-content_uploads_archicadwiki_bugs-elementsnotvisiblein3d--quickoptions.png wp-content_uploads_archicadwiki_bugs-elementsnotvisiblein3d--viewsettings.png wp-content_uploads_archicadwiki_missingobjectsattributes--picture1.png
Dimensions/Labels - Troubleshooting Guide
Known Issues Labels may be dislocated when opening an ARCHICAD 19 project in ARCHICAD 20 Affected version: 20 | Severity: workaround applicable | ID: 201188 Due to a fix in ARCHICAD 20 which corrects the position of mirrored and associated Labels cou...
wp-content_uploads_2016_06_mirrored-labels-1024x665.png wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_archicadwiki_troubleshooting-cutplanedimensionloss--dim222.png wp-content_uploads_archicadwiki_troubleshooting-cutplanedimensionloss--dim111.png
How to Create Custom Line Types
Create Symbol Line Type In our special example we are demonstrating how to create line types with letters in it, but the described steps can be applied to any custom line type. When creating custom line types, the stencil of the symbol may be drawn o...
wp-content_uploads_archicadwiki_customlinetypes--1.jpg wp-content_uploads_archicadwiki_customlinetypes--3.jpg wp-content_uploads_archicadwiki_customlinetypes--5.jpg wp-content_uploads_archicadwiki_customlinetypes--open.png
automata Graphisoft
  • 13287 Views
  • 0 comments
  • 2 likes
Editing Grids
Best Practice Grids are best set before sharing the project. If it is necessary to edit a grid element, it is best to have all other users release their reserved elements and you reserve all of the elements in the project. If your organization is lar...
wp-content_uploads_archicadwiki_teamwork-editinggrids--gridoffinwe.jpg wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_archicadwiki_teamwork-editinggrids--gridinfotag.png wp-content_uploads_archicadwiki_teamwork-editinggrids--gridinfotag2.png
automata Graphisoft
  • 2253 Views
  • 0 comments
  • 0 likes
Print Versus Plot
Both Printing and Plotting are available in ARCHICAD. In ARCHICAD 10, Printing and Plotting have been brought onto a “common platform” which resulted in the Print and Plot dialog boxes becoming similar to each other. However, there are still differen...
wp-content_uploads_archicadwiki_printingplotting--printplot-01.png wp-content_uploads_archicadwiki_printingplotting--printplot-03.png wp-content_uploads_archicadwiki_printingplotting--printplot-02.png wp-content_uploads_archicadwiki_printingplotting--printplot-04.png
  • 2134 Views
  • 0 comments
  • 0 likes
U3D - How to embed navigable 3D models in PDF documents
U3D (“Universal 3D”) is a file format for 3D data. It is a standardized three-dimensional data format with the purpose of facilitating 3D data exchange among programs of various kinds. Adobe Acrobat supports this format from version 7.0, so within a ...
How to make Curved Text in Archicad
The article is based on Dan Kunschik’s original post on ARCHICAD-Talk and has been updated for ARCHICAD 15. Summary of steps To create a curved text in ARCHICAD, a few tricks need to be employed. Text (created with the TextTool) can not be curved, so...
wp-content_uploads_archicadwiki_curvedtext--textarea.png wp-content_uploads_archicadwiki_curvedtext--alignment.png wp-content_uploads_archicadwiki_curvedtext--linesegment.png wp-content_uploads_archicadwiki_curvedtext--naming.png
automata Graphisoft
  • 5835 Views
  • 0 comments
  • 2 likes
Difference between Drawing and Figure Tools
This document was prepared in response to the Archicad-Talk question of when to use the Figure Tool rather than the Drawing Tool.The Drawing and Figure tools are Archicad features that allow the user to deal with drawings and images. Even though thos...
automata Graphisoft
  • 2189 Views
  • 0 comments
  • 1 likes
PDF file size and Fill choice
Files saved from ARCHICAD in 2D formats (PDF, DWG, DWF...) can be unusually large because of fill and line types used in the drawing. "symbol" type fills and "symbol" type lines explode in DWG and PDF - one line in archicad can break up to thousands ...
wp-content_uploads_archicadwiki_pdffilesizeandfillchoice--1_novectorfill66.jpg wp-content_uploads_archicadwiki_pdffilesizeandfillchoice--2_smaller125.jpg wp-content_uploads_archicadwiki_pdffilesizeandfillchoice--3_small125.jpg wp-content_uploads_archicadwiki_pdffilesizeandfillchoice--5_verybig125.jpg
Ed Brown Graphisoft Alumni
  • 5515 Views
  • 0 comments
  • 1 likes
How to Use Standard Details in a Project
This article explains how to embed one or more standard detail drawings into your Project. In this example, we will embed a balcony and Wall-Slab intersection detail into our Project, and place it onto a Layout. We will also create a marker which con...
wp-content_uploads_archicadwiki_standarddetailsinaproject--embedstandarddetail-01.png wp-content_uploads_archicadwiki_standarddetailsinaproject--embedstandarddetail-02.png wp-content_uploads_archicadwiki_standarddetailsinaproject--embedstandarddetail-03.png wp-content_uploads_archicadwiki_standarddetailsinaproject--embedstandarddetail-04.png
  • 1687 Views
  • 0 comments
  • 0 likes
How to Split a Line
There are several ways you can split a Line in ARCHICAD. The following describes some of the basic methods. (There are probably other methods you could come up with). Splitting a Line with Another Element In this example, we wish to cut the near-hori...
wp-content_uploads_archicadwiki_howtosplitaline--cutline_withline1.png wp-content_uploads_archicadwiki_howtosplitaline--cutline_withline2.png wp-content_uploads_archicadwiki_howtosplitaline--cutline_withline3.png wp-content_uploads_2016_06_Info_18x18.png
  • 7552 Views
  • 0 comments
  • 0 likes
ARCHICAD's 3D Views and 3D Documents
Originally published at AECBytes: http://aecbytes.com/tipsandtricks/2008/issue35-archicad.html. Written by Eric Bobrow (Principal, Bobrow Consulting Group) ARCHICAD makes it easy to create a Virtual Building, a 3D Building Information Model (BIM) of ...
wp-content_uploads_archicadwiki_archicad-s-3d-views-and-3d-documents--1.jpg wp-content_uploads_archicadwiki_archicad-s-3d-views-and-3d-documents--2.jpg wp-content_uploads_archicadwiki_archicad-s-3d-views-and-3d-documents--3.jpg wp-content_uploads_archicadwiki_archicad-s-3d-views-and-3d-documents--4.jpg
automata Graphisoft
  • 14183 Views
  • 0 comments
  • 0 likes
Sizing Text and Markers with Points
In ARCHICAD 9 and earlier, measuring symbols is one issue and measuring text adds an extra complication for anyone using Imperial units (e.g., US version). This article does not apply to metric users. Marker Size: For marker size, there are at least ...
wp-content_uploads_archicadwiki_sizingtextandmarkers--marker-points.png wp-content_uploads_archicadwiki_sizingtextandmarkers--point-point.gif
automata Graphisoft
  • 2348 Views
  • 0 comments
  • 1 likes
